KICKR MOVE Smart Trainer
¥230,000
With the introduction of fore-aft motion, the KICKR MOVE bike trainer allows your bike to move naturally for a more comfortable and realistic riding experience than ever before.
  • FEATURES
    • NEW - 8" (20cm) fore-aft motion responds to changes in riding tempo
    • KICKR MOVE base allows for additional side to side movement as well as the adjustable AXIS feet
    • Virtually silent operation
  • SPECS
    • Power Accuracy: +/- 1%
    • Maximum Power Output: 2200W
    • Minimum Simulated Grade: -10% (-8% with CLIMB)
  • SETUP
KICKR MOVE Benefits
A new reality
KICKR MOVE integrates multiple dimensions of movement into a wheel-off trainer - combining the ride feel that has made KICKR the Choice of Champions with true fore-to-aft and side-to-side movement.
Ultimate comfort
This smart bike trainer provides next level comfort to your indoor rides; the movement unleashed by its dual-axis motion reduces fatigue and improves overall efficiency, allowing you to train longer and harder than ever before.
Next level experience
KICKR MOVE moves with you. This freedom mirrors what you feel outdoors, bringing next-level realism, fun and engagement to structured workouts, virtual races and indoor rides.
KICKR quality guaranteed
Built to exacting standards, KICKR MOVE is incredibly stable, quietly powerful, precisely accurate and completely connected.
KICKR Smart Trainer
Next Level Experience
From pushing out of the saddle on an explosive attack, to finding your rhythm during a tough endurance effort, when you move, KICKR MOVE moves with you. This freedom mirrors what you feel outdoors, bringing next-level realism and comfort to your indoor rides or lock in your position for focused efforts.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR MOVE Features
Ultimate Comfort
KICKR MOVE provides next-level comfort to your indoor cycling rides; the movement unleashed by its fore-aft motion reduces fatigue and improves overall efficiency, allowing you to train longer and harder than ever before.
Lock-Out Option
When you want stability or a dialed-in position, KICKR MOVE features an option to prevent fore-aft movement and lock KICKR MOVE into place.
Erg Easy Ramp
Need to pause the workout for any reason? ERG Easy Ramp™ gets you back into the effort gradually instead of requiring a leg-busting effort to hit your power numbers.
Professional Grade Durability
Seamless Connectivity
Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR indoor bike trainers pair to most devices and applications so you have the most control over your training and ride data.
No limits training with Wahoo X
All Wahoo smart bike trainers and smart bikes come with a trial to Wahoo X, giving you access to SYSTM, a comprehensive collection of structured workouts and training plans, tailored towards your fitness objectives.
KICKR MOVE Specs
Tech Specs
  • Product Weight: 64 lb / 29 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-1%
  • Connectivity: Direct Connect, ANT+, ANT+ FE-C, WiFi and Bluetooth
  • Cassette: Includes 11-speed with 11-28 ratio
What's in the box?
  • KICKR MOVE
  • AC Power Adapter
  • Quick Release Skewer
  • Disc Brake Caliper Spacer
  • 1.8mm Cassette Spacer
  • Reversible hub spacer for 130mm and 135mm
  • AXIS Stiff and Easy Feet
Supported Devices
  • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
  • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
Bike compatibility
Bike Compatibility Check
Start
FAQ
Will the movement actually make my indoor training more comfortable for longer rides?
Independent reviews highlight the KICKR MOVE's clear comfort advantages, especially during long rides. Subtle side-to-side movement from weight shifting creates a more natural, engaging, and realistic feel in the saddle. Riders report reduced fatigue and improved efficiency, making it easier to train longer and push harder. By blending realism with comfort, the KICKR helps riders enjoy extended indoor sessions with less strain and greater performance potential.
How does the movement compare to outdoor riding - will it feel realistic?
The KICKR MOVE enhances indoor training with 8 inches of smooth fore-and-aft motion, creating a more natural and comfortable ride. This movement reduces sit bone friction, adds realism, and helps minimize strain on your bike frame. Its side-to-side motion is limited to about 2 degrees: a subtle yet effective motion that makes sessions feel more dynamic, realistic, and enjoyable, helping riders train longer with less discomfort.
Is this trainer reliable and accurate enough for serious training?
The KICKR MOVE delivers the same trusted performance as the flagship KICKR V6, sharing identical internal components, flywheel, and features aside from motion. Riders enjoy ±1% power accuracy, up to 2,200W resistance, and 20% gradient simulation for professional-level training. It also includes advanced features like ERG Easy Ramp for smoother interval transitions and Wi-Fi connectivity for faster, more responsive in-game performance.
What should I know about setup and getting the most out of my KICKR MOVE?
The KICKR MOVE is built for peak performance and stability. A convenient foot-activated switch lets you lock the motion for standing intervals, focused training, or transport. The movement feels especially natural when seated, reducing strain and boosting comfort. Remember to account for the 8-inch forward oscillation when setting up your riding station.
