TRACKR SPEED
¥5,250
The Wahoo TRACKR SPEED sensor is the sleek, magnet-less solution for capturing cycling speed and distance data. It easily mounts to your bike's front wheel hub, and the Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and bike computers. Tracking speed and distance data has never been this easy.
  • Part number: WFTRACKRSPD1
  • Dimensions: W 3.5 cm x H 3.2 cm x D 1.8 cm (W 1.4 in x H 1.3 in x D 0.7 in)
  • Weight: 13 g (0.5 oz)
  • Battery: CR2032
  • Battery life: up to 200 hours
  • Water rating: IPX7 (submersion up to 1 meter for 30 minutes)
  • Maximum hub diameter: 40 mm
  • Not compatible with spin bikes
  • No charging required: runs on a coin cell battery for up to 200 hours of use
  • Fits most hub sizes
  • ANT+ and Bluetooth Smart connect to both smartphones and bike computers
  • Two LEDs show device connection (blue) and speed detection (red)
In the box
  • TRACKR SPEED sensor and mount
  • CR2032 battery (installed)
  • Quick start guide
  • Important product info guide
TRACKR SPEED
TRACKR Speed
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 200 hours of use.
Universal Fit
TRACKR SPEED will fit with most hub sizes.
Dual Band Technology
Both ANT+ and Bluetooth Smart allow for a wireless connection to both smartphones and bike computers.
Visible Connection
Two LED lights show the sensor's device connection (blue) and speed detection (red).
What’s Included
  • TRACKR SPEED Sensor and Mount
  • CR 2032 Battery (installed)
  • Quick Start Guide
Tech Specs
  • Part Number: WFTRACKRSPD1
  • Physical Dimensions:
    • W: 3.5cm x H: 3.2cm x D: 1.8cm
    • W: 1.4in x H: 1.3in x D: 0.7in
  • Weight: 13 grams (0.5 oz)
  • Battery: CR2032
  • Battery Life: Up to 200 hours
  • Water Rating: IPX7 (submersion up to 1 meter for 30 minutes)
  • Maximum Hub Diameter: 40mm
  • Note: Speed Sensor is NOT compatible with spin bikes
TRACKR SPEED
