KICKR With Zwift Cog And Click
Choose your version
¥149,000
  • Power Accuracy: +/- 1%
  • Maximum Power Output: 2200W
  • Product Weight: 47 lb / 22 kg
  • Zwift Click mounts to any handlebar for quiet, intuitive virtual shifting
  • Auto-calibration keeps power accurate to within +/- 1%
  • KICKR AXIS feet flex 5° side to side, mimicking the feel of riding outdoors
  • Race Mode broadcasts power up to 10x faster over WiFi
  • Virtually silent operation
Complete your setup
KICKR only
Total ¥149,000
Zwift Ready
Works With ROUVY
with Zwift Cog and Click
KICKR Smart Trainer with Zwift Cog
Universal Compatibility
Zwift Cog fits almost any 8-13-speed bike, keeping maintenance to a minimum—just jump on and ride.
Virtual Shifting
Zwift Click attaches to any handlebar for quiet, intuitive virtual gear shifting at your fingertips.
Auto Calibration
Side-to-side Movement
Your ride. Your way.
KICKR with Zwift Cog and Click accommodates almost any 8-13-speed bike to maximize compatibility and minimize set-up. Whether you have multiple bikes or multiple riders, this is a seamless solution to get everyone in the house Zwifting.
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
KICKR Features
Realistic Ride Feel
Controlled Resistance
KICKR AXIS Feet
Professional Grade Durability
Seamless Connectivity
Connectivity
WiFi
Bluetooth Up to 3 Connections
ANT plus ANT+, ANT+ FE-C
2200 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy
20%
Maximum Incline
-10%
Maximum Decline
Belt Drive
Drivetrain
2200 Watts
Maximum Simulated Grade
20%
Minimum Simulated Grade
-10%
Product Weight
47 lb / 22 kg
Drivetrain
Belt Drive
Resistance Type
Electromagnetic
Power Accuracy
+/-1%
Connectivity
Cassette
Pre-installed Zwift Cog
Zwift Click
Hub Types
Adapters
Maximum Rider Weight
250 lb / 113 kg
What’s in the Box
  • KICKR
  • AC Power Adapter
  • Zwift Cog (pre-installed)
  • Zwift Click
  • Quick Release Skewer
  • 1.8mm Cassette Spacer
  • Disc Brake Caliper Spacer
Supported Devices
Pre-installed Zwift Cog on the KICKR drivetrain
Bike Compatibility
Start
How virtual shifting works with Zwift Cog and Click, bike compatibility, app connections, and what comes in the box.
What is Zwift Cog and Zwift Click, and how does virtual shifting work?
This KICKR comes with a pre-installed Zwift Cog, which replaces the traditional cassette, plus a Zwift Click shifter. Together they let you shift gears virtually in Zwift instead of relying on your bike’s mechanical drivetrain, so you can ride almost any 8-13-speed bike without swapping cassettes between riders or setups. The Cog is compatible with almost any 8-13-speed bike, keeping maintenance to a minimum, while the Click attaches seamlessly to any handlebar for quiet, consistent virtual gear changes at your fingertips.
The KICKR is designed for universal compatibility, working with virtually any bike. It comes equipped with multiple axle configurations, adapters, and a pre-installed Zwift Cog, so you can get riding right away. Features like a convenient carrying handle and tire size height adjustment make setup fast and simple. The included accessories, 130/135mm QR and hub spacers, 12x142/148 adapters, and a 1.8mm cassette spacer, ensure seamless fit with most modern bikes. With its thoughtful design and included components, the KICKR makes indoor training easy, flexible, and hassle-free, so riders can focus on performance instead of setup.
The KICKR delivers best-in-class connectivity for a seamless training experience. With robust 2.4 GHz Wi-Fi, support for up to three Bluetooth connections, a direct connect port, and full ANT+/ANT+FE-C compatibility, it pairs effortlessly with most devices and apps. The latest model introduces Race Mode, leveraging Wi-Fi to broadcast power data up to 10x faster, giving riders a competitive edge during critical race moments. This model comes with a pre-installed Zwift Cog and Zwift Click, so virtual shifting in Zwift is ready to go right out of the box.
Does KICKR with Zwift Cog and Click include a Zwift Membership?
KICKR with Zwift Cog and Click includes a one month free trial for new Zwift customers. After the free trial, Zwift access requires a subscription.
Compare smart trainers
¥149,000
Accuracy
Accuracy +/- 1%
Wireless Firmware Updates
Max Power Wattage 2200 Watts
Simulated Gradient
Zwift Cog & Click
Zwift Cog & Click Compatible
KICKR CLIMB Compatible
ERG Easy Ramp ERG Easy Ramp
RaceMode
RaceMode
KICKR Core 2
KICKR CORE 2
¥80,000 ¥99,000
Accuracy
Accuracy +/- 2%
Max Power Wattage 1800 Watts
Simulated Gradient
Zwift Cog & Click
RaceMode
RaceMode
¥115,000
Accuracy
*onboard power available
Max Power Wattage 1500 Watts
Simulated Gradient
