KICKR Smart Trainer
¥187,550
  • +/- 1% power accuracy
  • Side-to-side movement
  • Virtually silent operation
  • View More
  • Maximum Power Output: 2200W
  • 20% Simulated Incline
  • View More
The Wahoo KICKR Floormat is the perfect partner for your KICKR. It's water resistant and anti-slip to keep the trainer in place no matter how much you sweat! The thickness and material make it noise insulating, so your family will thank you during those early morning rides.
KICKR Benefits
KICKR Smart Trainer
Optimized flywheel technology
KICKR's 16lb high-inertia flywheel uses progressive algorithms to better replicate the sensation of riding outdoors on an indoor bike trainer.
Ready to ride
Auto calibration
KICKR uses an automatic calibration process to continuously offer accurate and precise power without a manual process by the user. Maximize every training session with power tracking to +/- 1% accuracy.
KICKR AXIS feet respond to rider tempo and body position changes with 5° of lateral side-to-side movement to make your indoor cycling feel more like riding outdoors.
KICKR Smart Trainer
Take your ride to new heights
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR features
REALISTIC RIDE FEEL
CONTROLLED RESISTANCE
KICKR AXIS FEET
PROFESSIONAL GRADE DURABILITY
SEAMLESS CONNECTIVITY
KICKR Specs
TECH SPECS
  • Product Weight: 47 lb / 22 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-1%
  • Cassette: Includes 11-speed with 11-28 ratio
WHAT’S IN THE BOX?
  • Refurbished KICKR
  • KICKR
  • AC Power Adapter
  • Quick Release Skewer
  • 1.8mm Cassette Spacer
  • Disc Brake Caliper Spacer
SUPPORTED DEVICES
Bike Compatibility
BIKE COMPATIBILITY CHECK
Start
FAQ
