KICKR CLIMB Indoor Grade Simulator
¥69,900
¥69,900
  • Free Economy Shipping
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Take your KICKR to another level and train for the climbs.
The latest innovation from Wahoo will literally take your indoor training to the next level! KICKR CLIMB indoor grade simulator is designed to work exclusively with the Wahoo KICKR Smart Trainers and when paired, it will add physical grade changes to your indoor training. When paired with Third Party Apps and devices, KICKR CLIMB blends ascents and descents with resistance changes for a truly immersive indoor training experience. The world isn’t flat; now, neither is your ride!
THE KICKR CLIMB IS ONLY COMPATIBLE WITH WAHOO SMART TRAINERS 2017 EDITION AND NEWER. PLEASE IDENTIFY YOUR KICKR BEFORE PURCHASE HERE.
Real-time grade changes
KICKR CLIMB physically adjusts your bike position to mimic real roads and mountain climbing. This allows you to naturally change position on the bike, engage climbing muscles, and improve pedaling technique to become more efficient and powerful climber.
App Controlled
Through the KICKR Smart Trainers, your KICKR CLIMB will replicate inclines and declines depicted in online training programs and mobile apps.
20% Maximum Incline
Through app control or manual control, the KICKR CLIMB can simulate inclines at a 20% grade *Exact grade changes dependent on bicycle size, wheel size and trainer type.
-10% Maximum Decline
Through app control or manual control, the KICKR CLIMB can simulate declines at a -10% grade *Exact grade changes dependent on bicycle size, wheel size and trainer type.
KICKR Smart Trainer Compatible
KICKR CLIMB was designed to work exclusively with Wahoo KICKR, KICKR CORE, and KICKR SNAP (2017 Editions and newer) to deliver the best possible riding experience. It pairs directly to the smart trainer for a connection that allows the trainer to control the KICKR CLIMB.
KICKR Desk Compatible
With proper placement, you can position the KICKR CLIMB under your KICKR DESK to complete your Wahoo ecosystem.
Wahoo ELEMNT Bike Computer Compatible
Connect an ELEMNT or ELEMNT BOLT to your KICKR and KICKR CLIMB system to relive the ascents and descents from your favorite rides or routes while training indoors.
Direct Proximity Pairing
Use the KICKR CLIMB’s remote to quickly and directly pair it to your Wahoo KICKR Smart Trainer. Press the remote button and you are ready to go!
Locked and Unlocked climbing modes
  • Unlock Mode allows the CLIMB to react to grade changes from external sources such as Zwift or TrainerRoad, or from your ELEMNT or ELEMNT BOLT GPS bike computer.
  • Lock Mode ensures the KICKR CLIMB will only respond to commands received from the remote.
Manual grade adjustments with remote control
KICKR CLIMB’s remote attaches to your handlebars so you can adjust the grade manually with a simple press of a button. When not in use the remote conveniently stores away in the top of the KICKR CLIMB.
Quick release and thru-axle bike compatibility
In addition to standard quick release hubs KICKR CLIMB also supports 12x100, 15x100, and 15x110 thru axle hubs.
LED Indicator Lights
The LED indicator light on the remote control alerts you as to when the KICKR CLIMB is searching and/or paired with a compatible KICKR Smart Trainer.
Professional Grade Durability
Designed to withstand your toughest climbs and hardest efforts.
Third party app compatibility
The KICKR CLIMB can match grade changes from select training platforms, such as The Sufferfest, Zwift and TrainerRoad, to create a truly immersive ride experience for virtual riding and structured workouts. Visit our FAQs, for a full list of compatible apps.
ELEVATED RIDE FEEL
The KICKR CLIMB quickly raises and lowers your bike to match ascents of up to 20% and descents of -10% when paired with the KICKR Smart Trainers. Climbing workouts and virtual courses are now more realistic than ever as the KICKR CLIMB recreates the grade changes in real time.
POWER POSITION
The KICKR CLIMB physically adjusts your bike position to mimic real roads and mountain climbing. This allows you to naturally change position on the bike, engage climbing muscles, and improve pedaling technique while indoors, to become a more efficient and powerful climber outdoors.
RIDE ENGAGED
Connect to the most popular online training platforms to create a truly immersive ride experience. KICKR CLIMB blends physical grade changes with resistance changes of the KICKR Smart Trainers to take your indoor ride to the next level.
Specs
Product Overview
Reviews
