Overview Features Reviews
ELEMNT MINI Bike Computer
¥11,500
Simple cycling essentials powered by your smartphone
Out of Stock
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 4.46ms
¥11,500
  • Free Economy Shipping
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Product Overview
Wahoo ELEMNT MINI is the sensor-based bike computer for those that want max data in a mini package! ELEMNT MINI is designed to work with Wahoo dual-band sensors only and offers two different configurations to meet your ride needs.
  • ELEMNT MINI + RPM Speed: The ELEMNT MINI pairs seamlessly with the Wahoo RPM Speed Sensor included in the box, as well as other Wahoo heart rate monitors and cadence sensors. It works with our free ELEMNT Companion App that allows you to set up your data fields, customize profiles, track performance, and share ride data effortlessly - no more confusing menus!
  • ELEMNT MINI + RPM Speed + Smartphone: When paired to your smartphone, the ELEMNT MINI gives you ride tracking, full ride data analysis, and call & text pop-up notifications.
ELEMNT COMPANION APP SET UP
The free ELEMNT Companion App effortlessly guides you through a step-by-step set-up so that you can create customized user profiles, track performance, update maps and firmware, and share ride data effortlessly.
1.8" DIAGONAL SCREEN
1.8" (45.7mm) diagonal display size that is larger than the leading competitor, so all your data is easy to see.
FULLY CUSTOMIZABLE SCREEN
There's a page for every element of your ride: a workout view with a complete look at performance metrics, a climbing view to track ascents in real-time, a map view to stay on course, live tracking, and more. All screens are fully customizable from within the ELEMNT Companion App. .
USER FRIENDLY BUTTONS
Two tactile and easy to press buttons on the top of the device allow you to quickly toggle through screens for all ride metrics.
WORKS WITH WAHOO DUAL-BAND SENSORS
The ELEMNT MINI is designed to work with the Wahoo TICKR heart rate monitors and Wahoo RPM speed & cadence sensors. It does not work with Wahoo sensors that are Bluetooth or ANT+ only.
WAHOO RPM SPEED SENSOR INCLUDED
Get on the road in no time! You can quickly pair the ELEMNT MINI and included RPM Speed Sensor be ready to ride in minutes with accurate speed, distance, and time metrics.
AUTOMATIC WORKOUT UPLOADS
Completed workouts will automatically upload to all authorized third party accounts via the ELEMNT Companion App.
Ride Tracking When Paired to Phone*
When paired with your smartphone, record your ride via the smartphone's GPS so you have a full ride history of your route and ride statistics.
Live Track Portal When Paired to Phone*
Live Track allows you to share a link by text or email using the ELEMNT Companion App, so that others are able to follow your ride in real-time on the Live Track web portal. Perfect for keeping you safely located by loved ones, tracked by a coach, or even meeting fellow riders in-route. This feature is only available if you are riding with your smartphone.
Text & Call Notifications When Paired to Phone*
Provides on-screen pop-up notifications to alert you when important contacts are trying to call or text. Only available if you are riding with your smartphone, and can be easily turned off with Do Not Disturb mode
*In phone mode, your smartphone must be with you on the ride and your ELEMNT MINI must be paired to the ELEMNT companion app.
Click here for ELEMNT MINI instructions
Specs
  • Part Number: WFCC2
  • Physical Dimensions: 41x58.4x17mm OR 1.6x2.3x.67"
  • Display Size: 1.8" (45.7mm)
  • Weight: 1.1 oz or 31 grams
  • Battery: Coin Cell
  • Battery Life: ~1 Year
  • Waterproof Rating: IPX7 (waterproof up to 5 ft)
  • Shock Proof: Yes
  • Wahoo RPM Speed sensor included
  • CLOUD, getReviews, 2.78ms
Product Overview
For more info, see Faq
Specs
  • Shock Proof: Yes
Reviews
