KICKR CORE
SMART BIKE TRAINER
BUY NOW
THE ESSENTIAL
INDOOR SMART TRAINER
Built to live up to its legendary namesake, KICKR CORE Smart Trainer delivers a realistic, accurate and quiet indoor ride. Designed with the toughest cyclists in mind, KICKR CORE is made to endure and withstand your most intense training sessions, watt for watt - season after season.
KICKR AT ITS CORE
KICKR CORE delivers a realistic, accurate, and quiet indoor training experience by using the proven flywheel technology, advanced algorithms, and integrated cadence measurement that originated with the iconic KICKR smart trainer.
BUY NOW
FLEXIBLE AND EASY SETUP
KICKR CORE is compatible with 8, 9, 10, and 11 speed cassettes and gives you the flexibility of adding your preferred cassette to the trainer, so that you can fully mimic your outdoor groupset. The Wahoo Fitness app offers guided set-up instructions to fine tune your ride and start training!
ECOSYSTEM COMPATIBLE
KICKR CORE is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup for your training needs.
MULTIPLE BLUETOOTH CONNECTIONS
KICKR CORE supports up to three Bluetooth connections simultaneously for a trouble-free workout experience.
DESIGNED TO ENDURE
The KICKR CORE was built to the quality that cyclists around the world have come to expect from Wahoo. Made to withstand your most intense training sessions, watt for watt — season after season.
TRAIN YOUR WAY
KICKR CORE pairs seamlessly with Wahoo KICKR Trainer Accessories, Wahoo ELEMNT Bike Computers, and Wahoo Sensors along with the most popular apps and software to create the ultimate indoor training environment.
SHOP TRAINER ACCESSORIES VIEW THE ECOSYSTEM
+/-2%
ACCURACY
POWER PRECISION
1,800
WATTS
MAX POWER
TRAIN WITH CONFIDENCE
REALISTIC RIDE FEEL
The legendary flywheel technology and tested algorithms emulate the power and experience of riding outdoors, especially when using virtual training platforms like The Sufferfest or Zwift.
HIGH-INERTIA FLYWHEEL
Engineered for precision, the 12 pound heavyweight flywheel in the KICKR CORE provides precise inertia needed to recreate an outdoor ride feel while training indoors.
CONTROLLED RESISTANCE
KICKR CORE automatically responds and adjusts resistance via your favorite app or software to simulate grade changes of up to a 16% incline.
PROFESSIONAL-GRADE CONSTRUCTION
Built from a robust steel construction, KICKR CORE stands up to years of heavy use from all types of cyclists.
VIRTUALLY SILENT
Continued improvements make KICKR CORE almost silent, the only noise you'll hear will be the sound of your chain when you shift gears as you power through your workout.
ADVANCED CONNECTIVITY
ANT+ and Bluetooth® capabilities allow the KICKR CORE to connect to smartphones, GPS devices, and FE-C enabled devices or applications.
MULTIPLE BLUETOOTH® CONNECTIONS
RIDE THE REVOLUTION
SHOP TRAINERS VIEW THE ECOSYSTEM
FREE 2 MONTH SUBSCRIPTION OF WAHOO SUF TRAINING WITH YOUR SMART TRAINER PURCHASE.
MORE THAN FASTER
Designed by world-class sports scientists, the Wahoo SUF Training app combines personalized workouts with yoga, mental and strength training to help you take your performance to the next level. One app. Everything you need to become stronger, faster and more focused.
Learn more
  • CYCLING
    Complete library of structured workouts designed by the world’s best coaches. The exclusive Four-Dimensional Power® platform personalizes all of your performance targets for the most effective workouts available.
  • YOGA
    Sessions to help build strength and flexibility in ways that translate directly to more speed and power on the bike. Enhance your powers of recovery and improve your range of motion to help avoid injury.
  • STRENGTH
    Easy to follow bodyweight-based program designed specifically for cyclists to build functional strength and turbo-charge your power and endurance on the bike.
  • MENTAL
    Train your brain and build mental toughness to help you get the most out of your training & deliver when it really counts.
WORKS WITH THE MOST APPS
RGT Cycling
LEARN MORE
ZWIFT
LEARN MORE
STRAVA
LEARN MORE
TRAINERROAD
LEARN MORE
FULGAZ
LEARN MORE
ROUVY
LEARN MORE
