RPM Bike Cadence Sensor
Discontinued
RPM Bike Cadence Sensor is Discontinued. As of June 2026, the Wahoo RPM Cadence sensor is discontinued and is no longer available for sale through Wahoo's website. Limited inventory still remains available for purchase at select retailers. Looking for other sensors to enhance your ELEMNT GPS Bike Computer? See your options here. Looking for support information for RPM Cadence? Read more here.
What to buy instead
TRACKR SPEED
TRACKR SPEED Newest sensor
Newest sensor, speed only
¥5,250 Shop Now
See all Cycling Sensors
The Wahoo RPM cadence sensor is your sleek little solution for measuring cycling cadence data. It is wireless, magnet-less, lightweight, and easily mounts to your bike's crank arm or to your shoe. Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and GPS bike computers. Collecting cadence data has never been this easy.
What replaced the RPM Bike Cadence Sensor?
The RPM Cadence Sensor has been discontinued and Wahoo does not currently sell a direct replacement. TRACKR SPEED is the newest sensor in the line, but it measures speed only. For all current bike sensors, see the bike-sensors category.
RPM Cadence Features
Dual Band Technology
Wireless Connection
Sleek, Lightweight Design
It only weighs 7 grams!
Cadence Measurement
Provides accurate cadence data during your ride
Peloton iOS Compatibility
RPM Cadence easily pairs with the Peloton Digital iOS App via Bluetooth to get real time cadence data during your spin workouts.
MYXFitness Compatibility
RPM Cadence easily pairs with the MYXFitness App via Bluetooth to get real time cadence data during your spin workouts.
Two Bike Mount Options
(1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
Shoe Mount Option
The RPM can be worn on your shoe for spin classes or use with multiple bikes
Visible Connection
Two LED lights show the sensor's device connection (blue) and cadence detection (red)
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 1 year.
Universal Fit
RPM cadence sensor will fit with most bikes and frame sizes
What's Included?
  • RPM Cadence sensor
  • CR 2032 Battery (installed)
  • Rubber Mounting Option
  • Zipties
  • Shoe Mount Option
  • 3M double sided tape
  • Quick Start Guide
Tech Specs
  • Part Number: WFPODCAD2
  • Physical Dimensions (LxWxH): 1.25" x.75" x 1"
  • Weight: 7 grams
  • Battery: CR2032
  • Wireless Signal Strength Up to 10 feet
