TRACKR HEART RATE Replacement Strap
¥5,380
This replacement heart rate strap is compatible with the TRACKR HEART RATE MONITOR. The soft, elastic material minimizes the chance of chafing and is easily hand washable. The two-snap connection is simple to get on and off, and the straps adjustable length gives you a secure, reliable fit.
Note: This item is not compatible with older Wahoo Fitness heart rate monitors.
What's Included?
  • 1 TRACKR Replacement Heart Rate Strap
Tech Specs
  • Strap Weight: 1.13 oz 0.07lb
  • Sweat Proof: Yes (handwash only)
  • Standard Strap Length: Adjustable from 26" - 35" for chests measuring up to 50" 67 cm - 88 cm for chests measuring up to 127 cm
  • XL Strap Length: Adjustable from 29" to 40" for chests measuring larger than 50" 72 - 102 cm for chests measuring larger than 127 cm
  • Note: This item cannot be returned or exchanged unless defective. Heart rate sensor pod not included.
