TICKR FIT heart rate armband uses optical heart rate technology to provide accurate heart rate and calorie burn data in the most comfortable form factor yet! Equipped with Bluetooth and ANT+ technology to seamlessly pair with fitness apps, smartphones, and GPS bike computers and watches. Worn on the forearm, the TICKR FIT heart rate monitor comes with an adjustable band that is designed for your most grueling workouts including running, cycling, fitness classes, and more. TICKR FIT has water-resistant technology and a rechargeable battery that lasts up to 30 hours.
Find a local dealer
TICKR FIT connects to smartphones, GPS watches & bike computers, and it verifies the connection by using convenient LED lights.
TICKR FIT uses trusted and time-tested optical heart rate technology to give you accurate heart rate and calories burned data.
TICKR FIT’s rechargeable battery is sure to power you through any workout. With up to 30 hours of battery life, you can be confident that TICKR FIT will be ready to go when you are.
Made from advanced performance materials, TICKR FIT’s band is designed to fit comfortably around your arm, yet fit securely during intense activity.
TICKR FIT HEART RATE is your perfect companion for rainy rides or a sweaty run. Rated IPX7, you can push your limits without worrying about the elements.
Spares & compatible add-ons for the TICKR Fit Armband.
