¥115,000
  • Maximum Power Output: 1500W
  • 10% Simulated Incline
  • View More
  • View More
KICKR ROLLR Benefits
Stable and Able
Simple Setup
Dual-Roller Design
Optimized Flywheel Technology
Ready. Set. Roll.
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
KICKR ROLLR Features
Controlled Resistance
Quick-Adjust Wheelbase Clamp
Ride with Power
Ecosystem Compatible
Connectivity
Bluetooth
ANT plus ANT+, ANT+ FE-C
1500 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy¹
10%
Maximum Incline
-10%
Maximum Decline
1500 Watts
Maximum Simulated Grade
10%
Minimum Simulated Grade
-10%
Product Weight
50 lb / 23 kg
Drivetrain
N/A
Resistance Type
Electromagnetic
Power Accuracy
Connectivity
Cassette
N/A
Hub Types
N/A
Adapters
N/A
Maximum Rider Weight
250 lb / 113 kg
What’s in the Box
  • AC Power Adapter
  • Owner’s Manual
Supported Devices
Riding on KICKR ROLLR
Bike Compatibility
Start
Your KICKR ride companion
Compare smart trainers
¥149,000
Accuracy
Accuracy +/- 1%
Wireless Firmware Updates
Max Power Wattage 2200 Watts
Simulated Gradient
Zwift Cog & Click
Zwift Cog & Click Compatible
KICKR CLIMB Compatible
ERG Easy Ramp ERG Easy Ramp
RaceMode
RaceMode
KICKR Core 2
KICKR CORE 2
¥99,000
Accuracy
Accuracy +/- 2%
Max Power Wattage 1800 Watts
Simulated Gradient
Zwift Cog & Click
RaceMode
RaceMode
¥115,000
Accuracy
*onboard power available
Max Power Wattage 1500 Watts
Simulated Gradient
Spares & compatible add-ons for the KICKR ROLLR.
1 item
