Overview Features Reviews
TICKR X Heart Rate Monitor
¥9,299
Bluetooth and ANT+ Heart Rate Sensor with Calorie Tracking and Memory
TICKR X Heart Rate Monitor is rated 3.9 out of 5 by 319.
  • y_2020, m_1, d_27, h_12
  • bvseo_bulk, prod_bvrr, vn_bulk_3.0.4
  • cp_1, bvpage1
  • co_hasreviews, tv_19, tr_300
  • loc_en_US, sid_WFBTHR02P, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 3.7ms
¥9,299
  • Free Shipping on Orders Over ¥12,000
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Product Overview
The TICKR X is the ultimate heart rate monitor, capturing both motion and intensity to give you the most effective workout. It tracks heart rate, calorie burn, running analytics and more! It even has built-in memory for heart rate and calorie data, giving you the freedom to train without a phone. Equipped with Bluetooth and ANT+ dual-band technology, it connects to most smartphones, GPS watches and bike computers. TICKR X is compatible with most popular fitness apps, making it an incredibly versatile workout tracker for all of your activities. No other heart rate training platform can compete with the TICKR X. Period.
Dual Band Technology
Both ANT+ and Bluetooth capabilities allow for a wireless connection to both smartphones and GPS devices at the same time or separately.
Real Time Heart Rate and Calorie Tracking
See workout data while you exercise, including vital metrics such as heart rate and calorie burn when connected to a smartphone or ANT+ device.
Internal Memory
With on-board memory that can record your workout, the TICKR X allows you to leave your smartphone behind and still capture valuable performance metrics, including heart rate, calorie burn, and workout duration. The memory holds up to a 16 hours of workouts!
Indoor Cycling Cadence
Captures your indoor cycling cadence when paired with the Wahoo Fitness App.
Running Analytics
Measures several other indicators of running form including vertical oscillation and ground contact time
Third Party App Compatibility
Works seamlessly with over 50 apps - including Zwift, The Sufferfest, Peloton for cycling and Runkeeper and MapMyRun for running.
Apple Watch Integration
You can pair your TICKR X to your Apple Watch via Bluetooth. Learn more here.
Visible Connection and Alerts
Two LED lights show the TICKR’s device connection (blue) and heart rate detection (red). Simultaneous blue and red double flash indicates when you add a marker during a phone-free workout.
Treadmill Mode
Special mode for tracking speed and distance data while on the treadmill
Cadence Measurement
Replaces a traditional footpod by providing stride rate data
Running Smoothness™
Built-in accelerometer measures running form across three dimensions to help you improve your individual form and become a stronger runner
Click here for TICKR X instructions
Specs
  • Part Number: WFBTHR02P
  • Physical Dimensions (LxWxH): 2.75" x .5" x 1.5"
  • Weight: 8.5 grams (without strap)
  • Battery: CR2032
  • Sweatproof: Yes (hand washable strap)
  • Strap Length: Adjustable from 23" to 48" (stretched)
Rated 5 out of 5 by from Great product Very satisfied with the product and with wahoo services.
Date published: 2019-12-26
Rated 5 out of 5 by from Better than Garmin HR monitor it replaced Recently bought this heart rate monitor to use with my Wahoo Element Bolt and am very happy that I did. I found it to be more comfortable than and better than Garmin HR monitor it replaced. Very simple to use and produces valuable data that goes from my Bolt to Wahoo app to Strava
Date published: 2019-12-11
Rated 5 out of 5 by from Easy to use and simple Linked with my garmin 735 (ANT+) for outdoor rides and my iphone (Bluetooth) for the trainer. Only negative is the running dynamics don't work with Garmin. I had the HRM- RUN4 and that gave me more metrics (as I use the garmin app as I have a garmin watch). So I should have gotten the standard verison not the X
Date published: 2019-12-09
Rated 5 out of 5 by from Cadence works on apple 4k w/kickr snap on zwift Cadence seems to be spot on when zwifting on my kicked snap w/ appl 4k. Wahoo tech said it wouldn't but seems fairly on target.
Date published: 2019-12-03
Rated 5 out of 5 by from Finally the heart rate monitor for me I have been using the TICKR X for a few weeks after trying several other brands. It is the one I will stay with.
Date published: 2019-11-29
Rated 5 out of 5 by from Very good heart rate monitoring live I used it for almost one month. I am using for triathlon training. Very good with run and bike, but while swimming it only give data of workout time. Heart rate tracing is not enough.
Date published: 2019-11-11
Rated 5 out of 5 by from I love it! I've had the Ticker X for many years and never had any problems. I recently lost mine so Im saving my pennies to buy another soon. I miss having it.
Date published: 2019-10-23
Rated 5 out of 5 by from comfortable, great features, dependable Works as expected, and as always, great customer support. The older version of this one lasted 8 years of hard nearly daily usage.
Date published: 2019-10-01
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.66ms
Product Overview
Internal Memory
Running Analytics
Treadmill Mode
Cadence Measurement
Running Smoothness™
For more info, see Faq
Specs
  • Battery: CR2032
Reviews
