NEW! Virtually Silent Operation |
The KICKR's new design offers an ultra quiet riding experience. |
NEW! Optimized Flywheel |
KICKR's new larger and heavier flywheel was specially engineered to provide riders with a more precise inertia needed to recreate an outdoor ride feel while training indoors. |
KICKR CLIMB Compatible |
Wahoo's KICKR CLIMB indoor grade simulator was designed in conjunction with the KICKR smart trainers to deliver a unmatched indoor training experience when combined. |
KICKR HEADWIND Compatible |
KICKR HEADWIND was designed to deliver innovative climate control to your indoor training experience. |
Thru Axle Compatible |
The new KICKR features 12x142 and 12x148 thru axle compatibility in addition to standard 130/135mm quick release. Click to find out if your bike is compatible. |
Disc Brake Clearance |
An update to the main mast ensures clearance for flat mount and disk brake equipped bikes. |
+/- 2% Power Accuracy |
Enhanced power accuracy to provide accurate power measurement and generate up to 2200W. |
20% Maximum Grade |
Maximum percent grade adjusts to simulate up to a 20 degree incline. |
LED Indicator Lights |
Visual confirmation that KICKR is powered, connected and transmitting via Bluetooth and / or ANT+ |
ANT+, ANT+ FE-C and Bluetooth Connectivity |
ANT+ and Bluetooth capabilities allow it to connect to both smartphones and GPS devices simultaneously or separately. An ANT+ FE-C connection allows the KICKR to be controlled from any FE-C enabled device or application. |
Professional Grade Durability |
Robust steel construction ensures the KICKR stays in place while you crank out the watts and stands up to years of heavy use. |
Controlled resistance |
When connected to your device, it automatically sets your resistance via your favorite app or software |
Realistic ride feel |
The KICKR flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic ride feel especially when using virtual riding/training platforms like Zwift and Trainer Road. |
Measures speed, distance, power, and cadence |
Get all your vital cycling metrics on your indoor ride. Cadence only available when paired with a Wahoo RPM Cadence Sensor that is included. |
Third Party App Compatibility |
Works with popular training apps such as Zwift and TrainerRoad. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart. |
Third Party Power Meter Support |
Compatible with a third party power meter. |
USB ANT+ Kit |
This kit is included with the KICKR trainer & Zwift bundle and comes with an ANT+ dongle and a 3 foot USB extension cable to connect your KICKR to Zwift. |
3 Month Subscription to Zwift |
After purchase, a code for a 3 month Zwift subscription will be emailed to you. Learn more about Zwift here. |
BONUS FEATURE! Free Trials from our favorite App partners |
KICKR bike trainer
RPM Cadence Sensor
AC Power Adapter
Quick Release Skewer
Disc Brake Caliper Spacer
1.8mm Spacer
Drive Side Adapter for 130mm and 135mm Quick Release
Reversible hub spacer for 130mm and 135mm Quick Release
Drive Side Adapter for 12x142 and 12x148 Thru Axle
Reversible hub spacer for Thru Axle
ANT+ dongle
3 foot USB extension cord
Will be emailed after purchase
iOS 11 or newer
Click here for compatible devices
BTLE enabled or pair with an ANT+ dongle
Get everything you need to get started training on Zwift! This exclusive bundle includes a 2018 Edition Wahoo KICKR smart trainer, an ANT+ dongle, USB cord, and a 3 month subscription to Zwift. The KICKR smart trainer provides the ultimate indoor training experience with it's realistic road feel and power accuracy. Zwift is an at home training game that connects you to cyclists around the world and provides an immersive, virtual riding experience.
