KICKR Headwind Bluetooth Fan
¥40,000
The KICKR HEADWIND is the first ever smart fan, designed with the cyclist in mind. Its Targeted Airflow Pattern mirrors the shape and position of a cyclist's body while riding. The KICKR HEADWIND is sensor controlled so as your speed or heart rate increases, so will the fan speed, and there are also 4 manual speed settings should you want to set your own ideal airflow. With speeds of over 30 mph (48 kph), the KICKR HEADWIND will keep you cool during the toughest training sessions.
Find a local dealer
  • FEATURES
    • Manual Mode: Select from four speed settings to set you ideal airflow
    • Speed Mode: Pair to KICKR or speed sensor to match fan speed to bike speed
    • Heart Rate Mode: Pair to ANT+ heart rate monitor to increase airflow as heart rate goes up
  • SPECS
  • SETUP
RIDER OPTIMIZED
The targeted airflow pattern of KICKR HEADWIND is designed to tunnel the fan's airflow at your body, where you need it most and provides a superior outdoor feel - indoors.
TAKE YOUR RIDE TO NEW HEIGHTS
Take your indoor ride up a notch with grade simulations of up to 20% incline.
MAX GRADE SIMULATION
10% 12% 16% 20%
KICKR HEADWIND FEATURES
POWERFUL AIRFLOW
With wind speeds topping out at 30 mph (48 kph) the KICKR HEADWIND will keep you cool during your hardest efforts.
TARGETED AIRFLOW PATTERN
The targeted airflow pattern of the KICKR HEADWIND is designed to mirror the shape and position of a cyclist's body while riding on a bicycle.
SENSOR BASED FAN SPEED CONTROL
Control the speed of your KICKR HEADWIND by pairing your ANT+ speed sensor, heart rate monitor, or smart trainer directly to the fan. As your speed or heart rate increases, so will the fan speed.
APP BASED FAN SPEED CONTROL
Pair to the Wahoo Fitness App via Bluetooth for easy fan speed control from your smartphone.
FOUR MANUAL FAN SPEEDS
Control the KICKR HEADWIND with a simple press of a button. Four (4) preprogrammed fan speeds allow you to select your ideal airflow.
KICKR DESK COMPATIBLE
The KICKR HEADWIND was specially designed to fit with the KICKR DESK. The wheels on the KICKR HEADWIND allow you to roll the fan into position when it is attached to your KICKR DESK.
KICKR HEADWIND SPECS
TECH SPECS
  • Part Number: WFBKTR7
  • Motor Spec: 120v 60hz
  • Dimensions (leg tucked): 16"L x 12"W x 19"H (41cm x 31cm x 48cm)
  • Dimensions (leg extended): 18"L x 12"W x 19"H (46cm x 31cm x 48cm)
  • Weight: 12 lb / 5.5 kg
  • Max Fan Speed: 30 mph/48 kph
  • Connectivity:
    • Bluetooth - Pair to phone to control the fan speed via app
    • ANT+ - Pair to speed sensor, heart rate monitor, or smart trainer to control fan speed
  • Adjustable Leg: Yes - 2 Positions
WHAT’S IN THE BOX?
  • KICKR HEADWIND Unit
