KICKR CORE smart bike trainers deliver a realistic, accurate, and quiet indoor cycling experience. Designed and built with durability and stability in mind to withstand your hardest rides - even if your legs don't.
No matter how you choose to ride or train, Wahoo X is the easiest way to get all your favorite training experiences for one incredible price.
11 SPEED CASSETTE
¥5,600
Complete your KICKR CORE with an 11 speed cassette (11-28T). Compatible with SRAM and Shimano.
10 SPEED CASSETTE
¥5,600
Complete your KICKR CORE with a 10 speed cassette (11-28T). Compatible with SRAM and Shimano.
KICKR TRAINER FLOORMAT
¥11,000
RIDE THE REVOLUTION
This smart bike trainer is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike trainer experience next level immersive.
YOUR RIDE. YOUR WAY.
KICKR CORE smart trainer includes a pre-installed cassette to match the gears on your bike. Choose from 8, 9, 10, 11, or 12-speed options, and you'll be ready to ride.
KICKR CORE is compatible with 8, 9, 10, 11 and 12 speed cassettes, giving you the flexibility to add your preferred cassette to the smart bike trainer, so that you can fully mimic your outdoor groupset.
MAX GRADE SIMULATION
10%12%16%20%
MAX POWER (WATTS)
1500w1800w2200w
KICKR CORE FEATURES
KICKR TO THE CORE
CONTROLLED RESISTANCE
When connected to your smartphone, tablet, computer or GPS bike computer, KICKR CORE smart bike trainer automatically controls your resistance based on the software or route.
POWER, SPEED, DISTANCE and CADENCE
PROFESSIONAL GRADE DURABILITY
KICKR CORE SPECS
TECH SPECS
Maximum Power Output: 1800 Watts
Maximum Simulated Grade: 16%
Minimum Simulated Grade: -10%
Product Weight: 40 lb / 18 kg
Drivetrain: Belt Drive
Resistance Type: Electromagnetic
Power Accuracy: +/-2%
Connectivity: ANT+, ANT+ FE-C, and up to three Bluetooth Connections
Cassette: Not Included
Hub Types: 130/135mm QR, 12x142, and 12x148 Thru Axle
Adapters: Includes 130/135mm QR adapter & hub spacer, 12x142/148 adapter & hub spacer, 1.8mm cassette spacer
Maximum Rider Weight: 250 lb / 113 kg
WHAT’S IN THE BOX?
KICKR CORE Smart Bike Trainer
Rear Leg
Front Leg
Nuts (x4)
Bolts (x4)
Hex Tool
Drive Side Adapter for 130mm and 135mm Quick Release
Reversible hub spacer for 130mm and 135mm Quick Release
Drive Side Adapter for 12x142 and 12x148 Thru Axle
